sammyredcat
#1 Posted : Wednesday, October 6, 2010 5:25:10 PM(UTC)
sammyredcat
Our chest freezer is not working perfectly....does the area of the external panel (has air flow slates/openings) housing the compressor need to be open to the air? Presently, the freezer is in a tight spot & the panel is up against a shelf & obstructed.
#2 Posted : Thursday, October 7, 2010 3:05:04 AM(UTC)
[COLOR="Blue"]does the area of the external panel (has air flow slates/openings) housing the compressor need to be open to the air?[/COLOR]
Yes they should be open to the air.
If not youur compressor will run hot, reducing it's efficiency and lifetime.
sammyredcat
#3 Posted : Thursday, October 7, 2010 6:33:10 AM(UTC)
sammyredcat
I assummed as much...thanks for the prompt reply
