Water dispenser lever works and when depressed water sprays. There is not a tube connected to the lever. Need to figure out tube part # and how to install. Have only found part number #4388152 Water Fitting Assembly including water tube at approx $40. That would seem to mean that entire freezer door needs to be dis-assembled and entire water line replaced.
