davidrbrown
#1 Posted : Wednesday, October 6, 2010 11:13:19 AM(UTC)
davidrbrown
The ice makeer green light is on and does not blink. No ice and there is no water in the tray. The water in the door works. Are there 2 water intake valves?
#2 Posted : Wednesday, October 6, 2010 3:45:16 PM(UTC)
David,
Make sure the water feeding tube into the ice maker is not frozen. If it is, use a hair dryer to clean it.
Swap the wires on the water inlet valve solenoids (on the back of the refrigerator), press the water dispenser release for a few seconds and check if there is water in the ice maker.
If there is no water and the water line for the ice maker is clean, replace the water inlet valve.
- The water inlet valve Part number: AP3192626
davidrbrown
#3 Posted : Wednesday, October 6, 2010 4:15:33 PM(UTC)
davidrbrown
Gene,
I kind of did that. I put a 120v directly on the ice maker part of the solenoid and water flowed in to the the ice maker. I guess there is not signal going to the solenoid from the ice maker. Do I just replace the ice maker and figure that is the problem?
-David
#4 Posted : Thursday, October 7, 2010 6:10:33 PM(UTC)
David,
If the water valve is good, you may want to check the wires from the ice maker plug to the water valve solenoid.
If there is nothing wrong, replace the ice maker.
- The ice maker Part number: AP4345120
GE Profile Arctica Fridge too cold (won't set above 28F) (Refrigerator & Freezer Repair)
by Rocket Rider 2/20/2021 1:47:57 PM(UTC)
GE Profile Arctica: ice/water dispenser panel dead (Refrigerator & Freezer Repair)
by Bogeyfreerfk 1/15/2016 1:07:28 PM(UTC)
GE Profile Arctica PTS22LCSARWW no sounds not cooling (Refrigerator & Freezer Repair)
by dar@unforgettable.com 10/22/2014 10:17:40 AM(UTC)
Freezer And Fridge Not Cold Enough - GE Profile Arctica (Refrigerator & Freezer Repair)
by lakeober 7/14/2013 8:43:21 PM(UTC)
Water and Ice not working on GE Profile Arctica (Refrigerator & Freezer Repair)
by dwcrossett 11/30/2012 3:21:27 PM(UTC)
GE Profile Arctica - capacitor burning smell (Refrigerator & Freezer Repair)
by CF3501 10/10/2012 4:57:57 PM(UTC)
GE Profile Arctica ice maker (Refrigerator & Freezer Repair)
by mmmcarroll 9/6/2012 11:13:52 AM(UTC)
GE Profile Arctica Fried the brand new Main Board (Refrigerator & Freezer Repair)
by Nightmare 6/22/2012 11:10:02 PM(UTC)
GE Profile Arctica Refrigerator Not Cooling or Freezing But Running (Refrigerator & Freezer Repair)
by mGalicia 5/29/2012 3:15:30 AM(UTC)
by dstump 11/23/2011 10:48:04 PM(UTC)
GE Profile Arctica Fan Clicking in Freezer (Refrigerator & Freezer Repair)
by Samson10 10/6/2011 8:33:22 PM(UTC)
GE Profile Arctica not cooling, panels don't work (Refrigerator & Freezer Repair)
by johndoe111 7/31/2011 7:33:27 AM(UTC)
GE Profile Arctica Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by Snap50 7/25/2011 6:11:51 PM(UTC)
GE profile arctica (Refrigerator & Freezer Repair)
by jasperfish 5/18/2011 6:14:19 AM(UTC)
ge profile arctica freezer temp 11 frig temp 39 (Refrigerator & Freezer Repair)
by jett40 5/4/2011 1:59:00 PM(UTC)
