kezhaya
#1 Posted : Wednesday, October 6, 2010 10:13:23 AM(UTC)
kezhaya
Hello- Had a problem with my Bosch tripping the breaker. At first once or twice during the cycle, then breaker would not reset at all. Found one of the main wires totally burnt up- Fixed that wire and reconnected the other two while I was there. Now the dishwasher comes on without popping the but does not work correctly still.
Now, when I turn it on it does the initial drain, but when the water is supposed to go in I can hear it in the pipe- but none goes into the washer. Just a slight buzzing on & off every few minutes like it is clicking through the cycles. 15 or so through the wash it will go through the drain again (even though no water) and continue on....
I have taken off the side panel and played with the red floater switch and the blue lever will push in and slowly come back out- but I have not taken anything over here apart yet.
Any insights out there??!?:confused:
#2 Posted : Wednesday, October 6, 2010 12:57:47 PM(UTC)
Check for 120 VAC to the water inlet valve while the control calls for water fill. Post the results.
Here are the breakdown diagrams and Replacement parts for Bosch SHU9925 UC/12 (FD 8003-) | AppliancePartsPros.com
kezhaya
#3 Posted : Wednesday, October 6, 2010 3:22:25 PM(UTC)
kezhaya
Don't know how to do that but I did order a new inlet valve, hopefully that will fix it.
#4 Posted : Thursday, October 7, 2010 5:23:03 PM(UTC)
I would not be so sure. Based on the information you posted in the first post, there is a chance for the control module to be bad too. That's why I recommended to check the voltage to the water valve.
kezhaya
#5 Posted : Thursday, October 7, 2010 6:35:43 PM(UTC)
kezhaya
I don't know how to do that. I read about the control module also but the water valve is about one quarter of the cost so I'm crossing my fingers. I guess that would be next on my list if it didn't fix it....
Guest (4)
