minnow73
#1 Posted : Wednesday, October 6, 2010 11:18:41 AM(UTC)
minnow73
We replaced the coils about 6 months ago when we had no heat. Worked great. No heat again. Replaced coils again, was not the problem apparently. There was no glow when we turned it on, so last night put in a new ignitor. Nothing. I want to order all the parts it may be at one time so we can get this thing FIXED! Please advise as to what parts you suggest it may be. Fuse? Flame sensor? Thank you:)
Joe / APP Team
#2 Posted : Wednesday, October 6, 2010 1:01:12 PM(UTC)
Joe / APP Team
Minnow,
I would reccomend (as you requested) replace the flame sensor
Part number: AP2910747
Located on the burner cone.
Also order and install the thermal fuse
Part number: AP3132867
Located on the blower housing.
Those are the only two basic, common, heat associated parts left, that you haven't replaced.
The remaining parts could be :
Timer
Temperature selector switch
Wire harness
Motor
These are not common failures, and I would not reccomend you replace these parts until you perform circuit and resistance checks with a VOM meter.
Good Luck,
:cool: :cool: :cool:
