dbrashear
#1 Posted : Wednesday, October 6, 2010 9:01:07 AM(UTC)
dbrashear
When switch is pulled to start no water flows into machine.
If I fill the machine manually everything other cycle works fine. (I also fill manually for rinse cycle)
Moved water temp switch to hot or cold, no change.
I took a guess and ordered an ATC switch.
Any help would be great
thanks
M# ATW4475TQ0
