2 Pages<12
#11 Posted : Monday, May 12, 2008 5:00:26 PM(UTC)
Hi misterfixall,
I found the wiring diagram for the stove and the installation instructions for this switch.
bpiranha
#12 Posted : Sunday, July 27, 2008 4:12:40 PM(UTC)
bpiranha
Here are some pictures of before/after of the infinite switch for Kitchenaid kitchenaid KECC560BBL2 stovetop. I hope this helps you.
If you need more pics, let me know...:)
Originally Posted by: kc135guy Go to Quoted Post
Maybe Gene can help me out.
I have an old infinite switch that doesn't match exactly with the new infinite switch. Pix attached.
I figured out the pink wire (power), the black and violet I already connected, but there are 3 orange that I can't figure out where they go.
If anyone can help out, please call me at 785-478-1286 or 785-220-3940. Or I can call you - no problem.
bpiranha attached the following image(s):
$sparkamatic
#13 Posted : Sunday, December 28, 2008 1:27:29 PM(UTC)
$sparkamatic
I have an 8 year old KitchenAid Cooktop, KECC567HSS and the left front (dual) burner is inoperative. It started to act up a few months ago and I suspected the Infinite Switch which is part #8203534.
I have never changed one of these and feel comfortable giving it a try. I did see in another thread that the directions for installing the swith talk about using provided jumper wires if the new switch wire lenght is too short which requires a "heat gun".
How easy is it to install an infinite switch? How long would it take a professional and what would one charge?
Before I order the part......................Thank you!:D
bpiranha
#14 Posted : Sunday, December 28, 2008 2:04:00 PM(UTC)
bpiranha
very easy and simple to do. Most of the time (1 hour) was consumed removing the stove from the countertop. If you know how to unplug and plug wires, its a simple task taking no more then 2 hours total. Make sure you take pictures before you begin, so you remember what goes where if your memory is failing like mine. :) Its well worth doing yourself to save some bucks. The switch is not cheap either.
Kitchenaid cooktop - combo burner only works as big (Oven Repair (including Ranges and Cooktops))
by beb123 9/2/2013 5:37:44 PM(UTC)
KitchenAid Cooktop—bottom right burner doesn't heat up (Oven Repair (including Ranges and Cooktops))
by szbz 10/16/2011 1:49:40 PM(UTC)
KitchenAid Cooktop (Oven Repair (including Ranges and Cooktops))
by Dr-Greg 4/8/2011 1:12:05 AM(UTC)
Replace spark module on Kitchenaid cooktop (Oven Repair (including Ranges and Cooktops))
by alenhoff 12/14/2010 4:12:26 PM(UTC)
Kitchenaid Cooktop problems (Oven Repair (including Ranges and Cooktops))
by kpendlet 4/27/2010 5:15:38 PM(UTC)
kitchenaid cooktop won't lite (Oven Repair (including Ranges and Cooktops))
by ehut1 9/23/2009 12:54:29 PM(UTC)
Parts for a Kitchenaid cooktop (Oven Repair (including Ranges and Cooktops))
by hht 8/3/2009 12:51:22 PM(UTC)
KitchenAid Cooktop Gas Comes out slow at start (Oven Repair (including Ranges and Cooktops))
by dgade89 12/29/2008 11:42:37 PM(UTC)
Kitchenaid cooktop spark intermittant (Oven Repair (including Ranges and Cooktops))
by Rich C 12/23/2008 8:40:34 PM(UTC)
KitchenAid cooktop won't spark (Oven Repair (including Ranges and Cooktops))
by nimsu71 6/10/2008 1:13:23 PM(UTC)
kitchenaid cooktop gasket (Oven Repair (including Ranges and Cooktops))
by mark31904 4/25/2008 6:17:34 AM(UTC)
kitchenaid cooktop won't shut off (Oven Repair (including Ranges and Cooktops))
by jappel2 3/20/2008 6:06:28 AM(UTC)
2 Pages<12
