juliedearth
#1 Posted : Wednesday, October 6, 2010 4:02:44 AM(UTC)
juliedearth
I ordered a door switch and need to know where the pink and the blue and the black wires connect to on the door switch itself. The door swith does not tell you. thanks julie:)
Joe / APP Team
#2 Posted : Wednesday, October 6, 2010 6:38:14 AM(UTC)
Joe / APP Team
Julie,
Is this the part you orderred ?
Part number: AP4319999
As you can see , you'll have 3 terminals to deal with.
Based on my wiring diagram this is how to wire the new switch:
White wire (neutral) will attach to the "COM" common terminal.
Yellow/Black wire(motor) will attach to the "NC" normally closed terminal.
Gray wire(light socket) will attach to the "NO" normally open terminal.
You may also need to replace the connector(s) on one or both of the wires,
If you have to , you may want to replace one wire at a time, so you don't get mixxed up.
Good Luck,
