The water dispenser has a slow leak. What could be causing this problem?
Can you be more descriptive on the problem?
Originally Posted by: Gene  Can you be more descriptive on the problem?
Gene. There is a slow drip from the tube that dispenses the water so I have to put a cup under it all of the time.
Sounds like the problem is a bad water inlet valve on the back of the refrigerator. - The water inlet valve Part number: AP3192626
Originally Posted by: drewton  There is a slow drip from the tube that dispenses the water so I have to put a cup under it all of the time. thanks!!!!!
