lucky_me
#1 Posted : Monday, October 4, 2010 8:26:49 PM(UTC)
lucky_me
My electric dry work but does not have any heat meaning it just blow cold air instead of hot air. Any idea would be appreciated.
Thanks,
lucky_Me
#2 Posted : Tuesday, October 5, 2010 2:50:11 AM(UTC)
Replacement parts for WHIRLPOOL LEC7858AN0 | AppliancePartsPros.com
First check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next I would check the heating coil (Item 9 in Section 3) should be around 10 ohms.
Then the thermal fuse (Thermal cutoff) ( Item 9 in Section 3) should be 0 ohms.
If this is blown then there are other things you should check as tyou have to find out why it blew.
