chughes
#1 Posted : Monday, July 23, 2007 10:23:51 AM(UTC)
chughes
Our dishwasher has a small leak that occurs during most cycles - at the times of transition. I have been able to see it happen. It is leaking not around the hose connection but under what may be the motor or pump - near the center of the machine. The amount of water that leaks is about the size of a melted ice cube.
Admin / APP Team
#2 Posted : Monday, July 23, 2007 2:53:14 PM(UTC)
Admin / APP Team
Rank: Administration
It's probably one of two things:
1. The main pump/motor seal is broken. Normally, this would cause a larger leak than what you are describing, but if the seal is just starting to go, it would probably not let too much water out. Click on the diagrams for Model HDA105Y-70WH. The seal I'm referring to is number 434 on the pump/motor diagram. There are two ways to fix this problem - rebuild the pump using a pump seal and impeller kit (more time and effort, less money) or replace the entire pump/motor assembly (more expensive, but a much quicker and easier repair). Instructions are included with both kits.
2. Small rubber seal for the pump drain valve shaft (located right above the solenoid, number 417 on the same diagram) is worn out. This will produce a minor water leak, much like what you are desciribing. The new seal also comes with instructions.
It's pretty easy to tell whether the problem is with the pump seal or the drain valve shaft seal. If the water is leaking from the bottom center of the motor, the pump seal is bad. If the water is leaking from the drain valve shaft (right above the drain solenoid), the shaft seal is bad.
Hope this helps. Let us know what you find.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Kenmore Elite 665.13929K015 Dishwasher Leak (Dishwasher Repair)
by JROTN 12/22/2022 5:12:45 PM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
dishwasher leak varies (Dishwasher Repair)
by scottsasa 1/3/2021 4:23:28 AM(UTC)
Delayed dishwasher leak (Dishwasher Repair)
by budflanksteak 12/11/2020 5:03:57 AM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Dishwasher leak at float (Dishwasher Repair)
by warrenmott1 1/2/2018 12:37:31 PM(UTC)
Kemore Dishwasher Leak (Dishwasher Repair)
by Chevyman22360 7/19/2017 11:40:09 AM(UTC)
