f8191z
#1 Posted : Saturday, October 2, 2010 9:51:29 PM(UTC)
f8191z
All functions work properly except the squeeling/screetching sound when the drum turns. Is there a repair manual for this dryer?
#2 Posted : Sunday, October 3, 2010 2:57:09 AM(UTC)
Replacement parts for LDE9800 models | AppliancePartsPros.com
I could not find a manual for this specific unit but the following does list a LDE9804 so with lick it will be close to yours
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Possible causes are the idler wheel, the rear support rollers, motor bearings or the front bearings (glides).
You may as well also check the belt condition and give the interipor a good cleaning.
It is always a good idea to check/clean your vent system when you have to work on a dryer.
