JPeachey
#1 Posted : Saturday, October 2, 2010 8:13:28 PM(UTC)
JPeachey
My tenant used the self cleaning feature of the oven and now it is stuck in the locked position and the oven door will not open. The lever will slide a little to the right if it is put back on the clean cycle; but it will only slide to the left a very small amount. I tried turning off the power and also doing the clean cycle again, but the door remained locked. Any advice/suggestions will be appreciated.
rmb
#2 Posted : Monday, October 25, 2010 11:26:37 AM(UTC)
rmb
I have same problem with Whirlpool oven- error codes F5 and E1. How do I replace the door latch if door is locked?
Guest (4)
