Rob W
#1 Posted : Thursday, July 24, 2008 2:33:10 PM(UTC)
Rob W
I read in an old post this problem was "keypad membrane". Not sure if this would apply to my model? Is this easy to replace? Is it worth fixing a 6 year old unit? Appreciate any guidance.
#2 Posted : Friday, July 25, 2008 2:49:18 PM(UTC)
Hi Rob,
The model number you posted does not come up. Verify and repost it, please.
Rob W
#3 Posted : Monday, July 28, 2008 5:55:53 PM(UTC)
Rob W
Gene,
Sorry. Correct model number is JVM1860SD002. Thanks. (I plugged in a couple times over the weekend and it worked for one cycle....it would then restart automatically again) Strange.
#4 Posted : Wednesday, July 30, 2008 4:01:46 PM(UTC)
Hi Rob,
The "F3" error code means a shorted key on the key pad. The key pad is a part of the control panel which has to be replaced. Is it worth or not you have to decide based on the condition of the unit.
- The part number for the control panel is AP3669104
Here are the break down diagrams for the GE microwave Model JVM1860SD002
