hello all I have a whirlpool ed22pqxfw01 does not restart cooling after defrost time if i turn the df a few clicks cc it starts until the next df time out but does not restart I installed new df timer 482493 and place black wire on term 1 since i was told it was a cumulative compressor run application.
the fridge ran all night and temp to operating range however it did not restart I had to turn new df cc untill it clicked on
All fans run, it cools but after DF time it never restarts cooling and temps increase to 56 in fridge area
what is the issue seems something is not allowing the timer to turn to next cycle please help me fix this I am not in a position to afford a new one and service in my area is a big challenge
thanks in advance
THIS FORUM IS DEAD!!!!!!! |
Thanks However the links do not work on this end
Coconut
Yes I am having the same problem here.
Hopefully it is just a temporary problem with the site. |
I had read in a earlier post that the fridge i have whirlpool model i have is a cumulative compressor which whould use the Version 2 wiring fig 3 on instructions the black wire show terminal 1 placement the links however never came active in the above post anyone have any further info if the part number of the fridge is a cumulative compressor run time application ?
coconut:confused:
