3 Pages123>
ripleys
#1 Posted : Sunday, December 2, 2007 9:09:33 PM(UTC)
ripleys
I have a customer that had there cabinets resurfaced and the cabinet guys pulled out the wall oven and disconnected the main power line that goes into the oven. The problem I ran into re installing it (because I was not the one to take it out) was there are 5 wires in the main power cord to the oven. Red, Black, White, ground and some blue wire. The blue wire has a spade terminal on the one end that goes into the oven, and the other end was joind in the box somewhere. I joined all the other wires accordingly and the oven works fine, but I have no digital display or oven light. There is no wiring diagram to be found anywhere on the oven so I am kind of lost as to how and where that blue wire comes into play. Any info or any place I might find a wiring diagram on line would be greatly appreciated.
Thanks in advance.
John
#2 Posted : Monday, December 3, 2007 9:08:32 PM(UTC)
Attached you will find the wiring diagram for the Jenn Air oven Model W130-C
File Attachment(s):
W130 wiring diagram.doc (53kb) downloaded 383 time(s).
ripleys
#3 Posted : Tuesday, December 4, 2007 6:43:12 PM(UTC)
ripleys
Thanks for the quick reply Gene, but the wiring diagram you gave me only shows a 4 wire supply and no blue wire. I am dumb founded as to where and why this wire is used, but it must be needed for something as before it was disconnected by the cabinet guys, there was a digital display and the oven light worked, now no light in oven and no digital display, yet the oven works and cycles fine. I think I am going to have words with the cabinet installers and hopefully they will remeber where they pulled the wire off. Thanks again.
#4 Posted : Tuesday, December 4, 2007 7:43:22 PM(UTC)
This is the only wiring diagram available for this model number.
Anne-Diane
#5 Posted : Wednesday, February 25, 2009 5:56:45 AM(UTC)
Anne-Diane
re your reply to question regarding Jenn Air Oven W130-C blue wire connection
This is no help... I have the same problem. I just moved and we cannot find where the blue wire needs to be attached. The diagram does not address the problem... no blue wire mentioned for one and I need to know where to connect it, not where it goes all through the oven. Please someone help!
Thank you
NJMom
#6 Posted : Friday, October 1, 2010 2:59:53 PM(UTC)
NJMom
Do you have the wiring diagram for the Jenn Air W130W?
I would greatly appreciate it.
Thank you.
#7 Posted : Friday, October 1, 2010 6:00:25 PM(UTC)
Thank you.
The only difference between these two models is a color.
NJMom
#8 Posted : Friday, October 1, 2010 6:07:25 PM(UTC)
NJMom
Thank you. I saw your post for the electrical diagram but it referenced a convection oven (W130C).
My oven is just an electric oven W130W.
If this is the same diagram that you posted previously, thank you ever so much.
The repairman said it would take him "HOURS" to figure out the problem without the wiring schematic.
I really appreciate your reply!!!
#9 Posted : Friday, October 1, 2010 6:25:12 PM(UTC)
...I saw your post for the electrical diagram but it referenced a convection oven (W130C)...
Why do you think this oven is convection?
"C" in the model number states for "black" while "W" in W130W states for "white".
NJMom
#10 Posted : Friday, October 1, 2010 8:30:02 PM(UTC)
NJMom
Well then, thank you ever so much!!!!!!
3 Pages123>
