merv rotzien
#1 Posted : Tuesday, September 18, 2007 7:53:03 PM(UTC)
merv rotzien
is the oven light cover threaded or how do you remove ?
merv rotzien
#2 Posted : Tuesday, September 18, 2007 7:59:09 PM(UTC)
merv rotzien
How Do You Remove Electric Light Bulb Protective Glass?
Admin / APP Team
#3 Posted : Wednesday, September 19, 2007 11:45:36 AM(UTC)
Admin / APP Team
Rank: Administration
ABP37800 does not come up as a valid model number, so I'm not able to see what you have, but typically oven light cover either has threads or is secured with a metal bracket.
If the cover is threaded, you may have to use some force to remove it. Be careful not to break anything. Also, keep in mind that you will probably have to replace the cover gasket.
Guest (4)
Replace Oven Light Switch (Oven Repair (including Ranges and Cooktops))
by Driller_D78 12/21/2010 8:32:51 AM(UTC)
replace oven light switch (Oven Repair (including Ranges and Cooktops))
by cmruddy 4/9/2010 8:50:12 AM(UTC)
