Will not drain, will go through all cycles but will not drain. All pipes clean no problem with power. Sounds like pump. If this is the case will the part come with instructions and will I be able to return the part if it does not fix the problem or is the wrong part unless you have a visual? Any help please.
THIS FORUM IS DEAD!!!!!!! |
