This model has 4 top burners, the 2 front burners can be adjusted to large or small burner surface. The left front will not change to the large surface. It burns small no matter how you flip the switch. Is this a burner thats bad or is it the switch or better yet, how can I determine which one it is.
The first thing I would do is check the rocker switch for continuity. The circuit should be closed when the switch is "on". If there is nothing wrong then the heating element is bad and has to be replaced. - The part number for the rocker switch is AP2125301 - The part number for the dual heating element is AP2592150 Here are the break down diagrams for the Frigidaire range Model FEF377CFSAGene.
