It worked fine then one day it stopped heating and making a loud buzzing noise when turned on. When used as a convection oven it works. But not when using the microwave.
Is there anything special i should be warned about when replacing these items? Is it just a matter of replacing them.
You will want to make sure you discharge the capacitor, you can do this by using 2 screwdrivers, put the screwdrivers in the terminals of the cap, one on each side and touch them together.
