jimek6
#1 Posted : Wednesday, September 29, 2010 10:49:06 AM(UTC)
jimek6
I am unable to open our Maytag dryer to check internal parts. Unable to pry top of dryer casing away from bottom of casing.
magician59
#2 Posted : Wednesday, September 29, 2010 1:36:37 PM(UTC)
magician59
Here's a parts breakdown of your dryer's cabinet. You'll see the screws in the lower front corners. Remove them and the front panel will swing up and away from the body. Front view replacement parts for MAYTAG DE4000 Dryer - Ele | AppliancePartsPros.com
jimek6
#3 Posted : Thursday, September 30, 2010 8:11:31 AM(UTC)
jimek6
Magician, Thank you. I had not seen the two front panel screws because they are below the break in the panel pointing slightly upward Removing the panel was very easy after removing the two screws.
