Greyfus
#1 Posted : Wednesday, September 29, 2010 9:18:15 AM(UTC)
Greyfus
Last week my dryer began to stop after only about 5 minutes of drying. The start button worked fine and even when it was continuously depressed, the dryer still shut off. I have replaced the motor, the high thermostat and the thermal fuse. Last night after I hooked up the motor, I was able to start it. This morning I had to pick up a new fan and install it. After, I got it all put back together, now the dryer won't start and the inside light doesn't come on? Beginning to think the dryer is possessed. I'm trying to get this fixed for my wife before I leave for Afghanistan tonight. Any suggestions are greatly appreciated! Thanks!
#2 Posted : Wednesday, September 29, 2010 2:52:45 PM(UTC)
Here are the parts
Replacement parts for KENMORE 11064932200 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406659.pdf
The most likely cause of your original problem is the motor overheating. The motor's internal thermal protect is the only device that will shut the unit down, then when the motor cools, the thermal protect resets and the unit can then be started again.
Could be:
1. The drum is binding and placing too much load on the motor. Try turning the drum by hand, it should rotate fairly easily.
2. The centrifugal switch to remove the start winding from the circuit is not opening. Leaving the start winding in circuit will cause the motor to overheat.
Could be the switches contacts are welded together. Could also be that the mechanism that activates the switch is not working but usually if this is the case yuou will not have any heat.
3. Could be the motor is on it's last legs.
Your current problem sounds like it is a power problem. Check that the unit is getting 120 volts between L1 and Neutral.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without tripping the breaker.
Greyfus
#3 Posted : Saturday, October 16, 2010 6:54:43 PM(UTC)
Greyfus
Originally Posted by: denman Go to Quoted Post
Here are the parts
http://www.servicematters.com/d...0Sheet%20-%203406659.pdf
Could be:
Thank you so much for your help. Sorry that it has taken me so long to get back to you. We have been out of town and away from the dryer.
I checked the drum and it does turn pretty easily, although not as easily as it did with the old motor - maybe just because the old motor was worn out??? I also flipped the circuit breaker like you suggested and now I have power - the light comes on but it still will not start. When I repeatedly push the start button, it sounds like there is a faint clicking coming from the timer dial. Is that normal? Where should I go from here? Couldit still be a power issue? Thank you again so very much!
#4 Posted : Sunday, October 17, 2010 3:42:50 AM(UTC)
[COLOR="Blue"]When I repeatedly push the start button, it sounds like there is a faint clicking coming from the timer dial. Is that normal?[/COLOR]
Hard to say without being here but I would guess yes.
In timed dry does the timer click and advance.
If yes it is another confirmation that the power is OK as it also uses the same power as the motor.
[COLOR="Blue"]Couldit still be a power issue?[/COLOR]
I have lost access to the wiring diagram but it does sound like the power that runs the motor should be OK. The light uses the same side of the line as the motor.
[COLOR="Blue"]Where should I go from here?so very much![/COLOR]
Check that when you push the door switch that the light goes off.
Check the connections at timer, perhaps when you replaced the motor one of them came loose.
Check other connections in the unit.
Recheck your motor hook up.
If all this fails it may be time to get a meter or a pro as you will have to check circuit paths and the easiest and safest way is to use a meter.
