I need to convert my Bosch stove from LP to NG and as the orifices are about $100 to replace, I wanted to drill them out instead. I am unsure as to which drill bit size to use and have not been able to find the info on-line.Anyone know where to look? Thank you.
Originally Posted by: hjf  I need to convert my Bosch stove from LP to NG and as the orifices are about $100 to replace, I wanted to drill them out instead. I am unsure as to which drill bit size to use and have not been able to find the info on-line.Anyone know where to look? Thank you. HJF, If I understand you correctly, You are converting back, from LP gas to Nat gas ? If you are converting back to Nat gas, you need smaller orifaces, not larger. Sounds like you'll have to purchase the parts, Good Luck, :cool: :cool: :cool:
