Mark Pawuk
#1 Posted : Wednesday, September 29, 2010 6:40:13 AM(UTC)
Mark Pawuk
After running the Convection Oven through the cleaning cycle it will not heat. Replaced the heating element, did not fix the problem. Any advice on what part or parts might need replaced?
Thanks,
Mark Pawuk
Joe / APP Team
#2 Posted : Wednesday, September 29, 2010 7:57:57 AM(UTC)
Joe / APP Team
Thanks,
Mark Pawuk
Mark,
Did you check the thermal fuse for a closed circuit ?
Part number: AP3879224
It's on the back of the oven, mounted to the oven wall, you may need to remove the unit from the cabinet.
If that fuse is open,(one shot fuse ) you will also need to check for the door closing and sealing proper, and the cooling fan is running properly.
Good Luck,
Mark Pawuk
#3 Posted : Wednesday, September 29, 2010 10:22:59 AM(UTC)
Mark Pawuk
Thank you for your help
Joe / APP Team
#4 Posted : Wednesday, September 29, 2010 1:15:43 PM(UTC)
Joe / APP Team
You're Quite Welcome,:D :D
