bginth
#1 Posted : Wednesday, September 29, 2010 4:43:35 AM(UTC)
bginth
I have a maytag dryer that only heats up partially. I found the exhaust hose and lint vents completly full. They are clean and the thermal fuse tests ok. The dryer heats up a bit but doesn't get completely hot. Any suggestions next.
#2 Posted : Wednesday, September 29, 2010 2:54:48 PM(UTC)
A model number m,ay help others help you.
Could be a grounded element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
bginth
#3 Posted : Thursday, September 30, 2010 4:24:18 AM(UTC)
bginth
It is a Maytag LGT 6634DQ1. Thanks for your response. I'll check it out.
#4 Posted : Thursday, September 30, 2010 5:13:01 AM(UTC)
Your unit looks like a gas dryer so please ignore my post.
Guest (4)
