marcia1
#1 Posted : Monday, November 26, 2007 6:54:03 AM(UTC)
marcia1
I have a front loading bosch washer that has a mildewy smell. It's making my laundry smell that way-especially my towels, even if I use fabric softner. I've even tried using softner sheets in the dryer, but that doesn't help either. I've noticed a little bit of water is always left in the rubber part of the doorway. I try to use a paper towel to dry it up-has anyone else had this problem?
#2 Posted : Monday, November 26, 2007 5:57:15 PM(UTC)
What is the model number of your washer?
maguire
#3 Posted : Wednesday, July 23, 2008 7:44:48 PM(UTC)
maguire
Ours does the same and Bosch says that every once in a while you have to pour some bleach in and run through a cycle ! Sucky design , But they were well aware of it! I hate mine. Now i'm having problems with the thermal reset button popping on my dryer all the time and I just changed the dryer vent and used solid pipe
