FEROIZ
#1 Posted : Tuesday, September 18, 2007 5:10:58 PM(UTC)
FEROIZ
I have problems recently with my Norge, model LWN203W, It overflows and It never stops, so all the water is draining from inside the machine.
What I need to do first ? Change the water level, clean it??
Please help me
Matt / APP Team
#2 Posted : Wednesday, September 19, 2007 4:01:23 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
Click here for parts list.
If the water can be turned off with the timer then I would test the water level switch and pressure hose (may fall off or get a hole). If the water doesnt shut off with the timer or unplugging it then I would check for a sticking water valve.
Click for water level switch.
Click for pressure hose.
Click for water valve.
These instructions are for Whirlpool but the ideas are basic enough that they should prove helpful.
Test procedures.
