Yes, order the timer and keep us posted. Good luck.
:) Gene. I finally got around to installing the new timer switch on Saturday. I ran the dishwasher starting with the pots and pans cycle all the way through heated dry with every button on. It works perfectly! THANK YOU VERY MUCH!
Originally Posted by: jev  :) Gene. I finally got around to installing the new timer switch on Saturday. I ran the dishwasher starting with the pots and pans cycle all the way through heated dry with every button on. It works perfectly! THANK YOU VERY MUCH! You are welcome. I'm glad you were able to fix it. Thank you for the feed back. Gene.
