i replaced with part#ap3182782(2255233) that i have got from you but still not working (light in ref. side and tempetore light in cotrl box)
You will need to check the connector pins, sometimes they work loose when you plug in the connector. You can also trace the wires that go to the light and see if there is continuity.
