2 Pages12>
jev
#1 Posted : 14 years ago
jev
:confused: PLEASE HELP! Start the timer dial on pots and pans or normal wash. The timer will run for a while. It will fill, wash, drain and refill and start to wash and then the timer stops. The timer dial has to be operated manually for each stage to finish the whole wash cycle.
If the dishwasher is turned off and not run for awhile the timer will work in any stage of the full wash cycle and the drying stage. It will eventually stop.
The boost thermostat has been replaced and that hasn't made a difference.
Thank you for your help.
#2 Posted : 14 years ago
Does the Heating Delay light stay On when the timer stops?
Here are the breakdown diagrams and Replacement parts for MAYTAG DWU9202AAE Dishwasher - Undercounter | AppliancePartsPros.com
jev
#3 Posted : 14 years ago
jev
Yes the heating delay light stays on when the timer stops. I tested it this morning. I started the dial on NORMAL WASH and it kept working all the way through LIGHT/CHINA The timer stopped and I let it sit for a while and nothing happened. I opened the door part way and let it sit for about 5min. Shut the door and the timer dial started working again and the washer started going again. The heating delay light came on. I checked to see if the timer was running and it wasn't. The heating delay stayed light on for almost 15 minutes then went off. The timer started up and the dish washer ended that part of the cyle and the quit. The timer was not running. I opened the door and there was still water in the washer. I helped the dial manually to finish it up.
jev
#4 Posted : 14 years ago
jev
Is there any other trouble shooting I can do to figure out what is wrong with the dishwaher? Thank you.
jev
#5 Posted : 14 years ago
jev
#6 Posted : 14 years ago
Sorry for the delay.
Check the heating element for continuity. If the heating element is good, replace the timer.
- The heating element Part number: AP4110787
- The timer Part number: AP4113633
dgdl441
#7 Posted : 14 years ago
dgdl441
1) More pictures available on our website www.nikeok.com2) Authentic quality, Wholesale price 3) Send the items to you within 24 hours after payment4) Shipping time: 4 -7 working days 5) Shipping types: EMS, DHL, TNT, UPS, FedEx6) Payment: Paypal, western union, money gram7) Well packaged to protect items demanding8) No order limitation. The more you order, the lower price we offer.Our main products list is as below:1) sports shoes: ******** shoes, ******** shox, Air Jordan, Jordan 2010, AF1, Jordan Fusion, Air max, Dunks, Puma, Bape, Gucci, Prada, ACG, Alife, Cole haan, Timberland boots, ect.2) Handbags: Chanel, Chloe, Coach, D&G, LV, Fendi, Gucci, Hermes, Prada, Juicy, Jimmy choo ect3) T-shirts: Affliction, BBC, POLO, Lacoste, ED-Hardy, GGG, A&F, Christan Audigier, Coogi, G-Star 4) Jeans: Red Monkey, True Religion, BBC, Christan Audigier, Artful Doger, bape, ect5) Jerseys: NFL, MLB, NBA, NHL6) Hoodies: Bape, BBC, LRG, CLH, ED hardy, Evisu, Gino Green Global, Deep ect7) Watches, Sunglasses, Belt, Hats/Caps, AccessoriesWe sincerely hope to establish business relationship with all friends from domestic and abroad. Hope to cooperate with you and look forward to your reply soon. Welcome order our shoes, we will give you the best price and services. Please feel free to log on to our website at www nikeok com and contact us at service@nikeok.com
jev
#8 Posted : 14 years ago
jev
:) Gene, sorry I didn't reply sooner. I didn't have a chance to check the heating element until this morning. I haven't used a ohm meter very much. I set the dial at 200k and got a reading of 22.3. The manual says that it should have a reading of 22. I am assuming that the element is good and am going to order the timer. Thank you for your help! JEV.
#9 Posted : 14 years ago
JEV,
You have to set the ohmmeter on lowest possible scale.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
jev
#10 Posted : 14 years ago
jev
I went back and checked and found out I had the scale on 200 not on 200k. The meter read 22.3. So I'm thinking I should order the timer.
2 Pages12>
