Hello, i´m a noob here, first of all, congrats for this great support forum, i´m a drycleaning machines technician from Portugal.. I´ve found lots of great information here in this forum, but i´m having problems with my dishwasher.. It´s a balay dishwasher, (bosch siemens group ), they are identical to bosch in majority of the aspects.. it gives no fill error, with help provided by this forum i already checked the inlet solenoids and electrovalves, they are ok and the machine fills, but keeps filling until the floater activates the drain pump, i´m thinking that the pressure switch (or the device that controls level) is faulty, but i can´t find it, the machine has a flow switch between the connections os the heater and that one is fine too, i took a few pictures to see if someone could help me findind the water level device.. Any help would be highly appreciated, Thanks in advance. yugoport attached the following image(s):
it seems that i cant post links to the pictures:confused:
