lvargas
#1 Posted : Thursday, September 16, 2010 8:34:01 AM(UTC)
lvargas
After finishing the cycle, the water came up agin in the tub,I already checked the hose (attached to the garbagge disposal), is working fine, I do not what else to do.
#2 Posted : Thursday, September 16, 2010 12:47:48 PM(UTC)
Remove the filter frame (#543 on the diagram). Unscrew and check the piston & nut assembly (#564).
You can find more information in one of our previous threads: http://forum.appliancepartspros...er-wont-drain-fully.html
- The piston & nut assembly Part number: AP2617344
lvargas
#3 Posted : Friday, September 17, 2010 3:37:04 PM(UTC)
lvargas
Thanks.
I tried that there is no problem with the piston, the water is still in the tub, the pipe connected to the garbagge disposal is ok because the water flows good!
How can I check if the water valve is working, because the tube is full again and thet water came trough that line and the water is hot.
#4 Posted : Monday, September 20, 2010 12:48:20 PM(UTC)
Sorry for the delay.
I'm afraid I did not get clear what is wrong with your dishwasher. It does not drain properly or it keeps filling with water when the dishwasher is off?
If it keeps filling with water while the dishwasher is off and the door is open, replace the water inlet valve. No doubts about it.
- The water inlet valve Part number: AP2039343
lvargas
#5 Posted : Monday, September 20, 2010 1:01:46 PM(UTC)
lvargas
Thanks,I will change that part.
#6 Posted : Monday, September 20, 2010 1:15:38 PM(UTC)
lvargas
#7 Posted : Saturday, September 25, 2010 8:51:28 AM(UTC)
lvargas
Thanks Gene my Dishwasher is working like a new one!!!.I could replace the inlet vale and it is working !!
#8 Posted : Saturday, September 25, 2010 3:12:13 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Thank you for the feed back.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
