mikkonen
#1 Posted : Tuesday, July 22, 2008 5:36:43 PM(UTC)
mikkonen
my kenmore fridge leaks water on floor after use of icemaker or water dispenser. it leaks only after you use these two features. I have cleaned the drain in freezer and the leak still occurs.
#2 Posted : Wednesday, July 23, 2008 5:33:05 PM(UTC)
The first thing I would do is check all water lines on the back and under the refrigerator and the water inlet valve on the back.
