kmbrlyfrantz
#1 Posted : Thursday, September 23, 2010 3:30:22 PM(UTC)
kmbrlyfrantz
Hi there~
I used the Self Clean mode today and all was well. Tonight it won't heat *either element*. This is an electric single oven.
I need help because if I can fix this *I installed it* then I'd prefer that!
#2 Posted : Thursday, September 23, 2010 6:09:56 PM(UTC)
Replacement parts for WHIRLPOOL GBS277PDQ11 27" Built - in Electric Single Convection Oven (gold Line) | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If power is OK then the thermostat (TOD) is next (item 37 in Section 1)
Remove power from the unit and one wire to the TOD and check it.
It should be 0 ohms.
btec
#3 Posted : Sunday, November 28, 2010 1:57:41 PM(UTC)
btec
I have the same problem after cleaning the oven. Checked the therm and it is open. Does it sound like it could be the problem.
#4 Posted : Sunday, November 28, 2010 6:07:26 PM(UTC)
Yes it does sound like the culprit.
Guest (5)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Whirlpool oven not heating fully (Oven Repair (including Ranges and Cooktops))
by msubully82 5/8/2015 8:52:02 PM(UTC)
Whirlpool Oven Not Heating Properly (Oven Repair (including Ranges and Cooktops))
by Crash55 1/30/2013 2:08:45 PM(UTC)
by Jinsmom 1/11/2010 3:48:03 PM(UTC)
Whirlpool Oven not heating fan runs continously (Oven Repair (including Ranges and Cooktops))
by drivephang 8/20/2008 10:01:26 AM(UTC)
by drivephang 8/20/2008 9:59:10 AM(UTC)
