browndiva
#1 Posted : Tuesday, July 22, 2008 11:47:57 AM(UTC)
browndiva
I was told that the oven control thermostat needs to be replaced:confused:. I was unable to turn the oven off and the silver knob that goes into the themostat cover just spins. What part do I need? It may possibly be AP3427505. Need help please!
abadfish66
#2 Posted : Tuesday, July 22, 2008 12:14:46 PM(UTC)
abadfish66
Item# 17 in section 2 is your thermostat control. Model JGBS21HED2WW
Pull the knob off, if you can freely move the shaft around without resistance you need to replace the thermostat control, check the knob itself, it could just be cracked or broken.
browndiva
#3 Posted : Tuesday, July 22, 2008 12:48:11 PM(UTC)
browndiva
With the cover off the shaft moves around easily. Thanks for your help!
abadfish66
#4 Posted : Tuesday, July 22, 2008 12:57:51 PM(UTC)
abadfish66
Then you need the thermostat, item# 17
