When I was using my oven I heard a loud buzzing noise and the main oven quite working. Everything else seems to work (stove top, bottom small oven and the clock). Does anyone know what could be wrong?
A complete model number will help us to help you.
First, visually inspect the element in the oven. If it apears broken or burnt through, it will need to be replaced. [COLOR="Red"]Don't attempt to remove it until the unit is disconnected from the power[/COLOR].(Turn it off at the breaker). Tell us what you find.
If you have 240 VAC at the outlet, you may have a bad relay on the circuit board.
