AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Whirlpool built-in Microwave vent grille replacement
I am trying to order a replacement part for model #MH6150XLQ0 Whirlpool built-in microwave. The original grille vent installs with a few screws above the microwave door. The part # AP3855006, $44.88 was recommended as a replacement, but no information was available for how the part is installed.
Can you confirm that the part installs with a few small screws????
thx.
Originally Posted by: RASlifkin  I am trying to order a replacement part for model #MH6150XLQ0 Whirlpool built-in microwave. The original grille vent installs with a few screws above the microwave door. The part # AP3855006, $44.88 was recommended as a replacement, but no information was available for how the part is installed.
thx. Ras, Based on your information AP3855006 is a white colored upper vent trim. It is a direct replacement part for the existing trim on your unit, and will mount to the cabinet with screws on the top and tabs on the bottom. Based on the information I have here. Good Luck, :) :) :)
Thanks for your help, Joe. I'll place the order right away. Originally Posted by: RASlifkin  I am trying to order a replacement part for model #MH6150XLQ0 Whirlpool built-in microwave. The original grille vent installs with a few screws above the microwave door. The part # AP3855006, $44.88 was recommended as a replacement, but no information was available for how the part is installed.
thx.
Originally Posted by: RASlifkin  Thanks for your help, Joe. I'll place the order right away. RAS, You're quite welcome. Have a good day, :) :) :)
Microwave Repair
