tedbuck
#1 Posted : Wednesday, September 22, 2010 8:27:13 AM(UTC)
tedbuck
The spinning cycle is progressively becoming louder, grating (bad bearing type noise). Spinning the drum/washplate by hand generates the same noise. I'm told the driver hub needs to be replaced; part # 280145. I'd like to view the installation instructions beforehand, or some overview on proceedure. IE can this be done w/o tipping the machine over. There are other posts on this which >$200 parts were required. The above part is <$20. No posts/threads to replace part as I've been advised.
tedbuck
#2 Posted : Sunday, November 14, 2010 3:22:58 AM(UTC)
tedbuck
My question was never answered and as a follow up I did resolve and determine that there was a defective bearing in the drive shaft assembly.
A new drum (outer) was required as the bearing assembly is not serviceable.
This is not a difficult repair with some "how to" instructions which I was able to find in bits and pieces in various sites.
The cost for having this repaired by a service company would have been approximately 60% of a new washer. I didn't find one company locally that recommended repairing out of warranty.
Guest (4)
