Cheesehead
#1 Posted : Tuesday, September 21, 2010 2:49:26 PM(UTC)
Cheesehead
We have a Whirlpool duet dryer, that wont do anything when you push the control button, I did the tech sheet and thought I had it narrowed down to the Machine Control Electronic's board, Replaced it same results, before I replace the console electronics panel, any insight or direction someone can suggest:cool:
#2 Posted : Wednesday, September 22, 2010 2:42:32 AM(UTC)
Have you checked:
The power.
The thermal fuse.
The belt switch.
Have you tried any of the diagnostics?
Cheesehead
#3 Posted : Wednesday, September 22, 2010 5:13:11 AM(UTC)
Cheesehead
Yes, I ran the tech sheet, checking power, button funtions ect. It all pointed to the machine elec. board. The machine now operates, but the digit/ time display is unreadable. Is it possible a spike fryed both the display, and machine boards.
#4 Posted : Wednesday, September 22, 2010 5:48:18 AM(UTC)
Since the display drivers and the display seem to be all on the control board my first thought would be that you have received a defective control board.
Cheesehead
#5 Posted : Wednesday, September 22, 2010 12:54:20 PM(UTC)
Cheesehead
So, since the board I bought has a no electronics return policy, is there a check for just the display, I have the tech sheet for readings, ohms ect but no specific test for the digit display. I think I'll install the original board and see what happens that way. Thanks for your input, were really greatfull
