My dryer is making a thud sound while running. It sounds like a shoe in the dryer. I have read that the dyer slides or belt would be the first things to look at.
How do I tell if they are bad? Where can I find a service manual for this dryer.
Thanks,
Seth
Setn, You have to take the dryer apart to check the rear bearing (#12 on the diagram), the drum glide (#24) and the felt seals (#20 & #21 on the diagram). The disassembly instructions are attached to the reply. - The rear bearing assembly Part number: AP2142648
Since the dryer is 4 years old. Are you recommending I replace all of those parts or just any of them that look worn?
Thank you for the help.
Seth
Setn,
I would replace only worn out parts. It's also a good time to clean the dryer.
