Maytag in storage for 10 years and went into storage with maybe 2 washings; so maching like new. Tried it yesterday for first time and it filled with water but nothing beyond that. Just a humm. I think something must be locked up from being in storage so long. Any ideas. Thanks
Originally Posted by: magician59  Complete model number? Model number is LAT9206AAE.
I would replace the belts. Also a good idea to check that the motor can easily slide on its base. If not, some lubrication is in order. Being in storage can also affect the hoses, so look for leaks as the machine operates. Keep us posted.
Originally Posted by: magician59  I would replace the belts. Also a good idea to check that the motor can easily slide on its base. If not, some lubrication is in order. Being in storage can also affect the hoses, so look for leaks as the machine operates. Keep us posted. Thanks, I will keep you posted on progress.
