I Have a Kitchen Aid Convection/Micro It started beeping intermittently and some of the funtions where not working. I had a tech come out and he said it was my controll panel...I replaced the controll panel and all was good for about a month. It's doing the same thing as it did prior to the replacement of the new C-Panel, It there something else I should be checking for?
P.S. Appliance Parts Pros Service rep Replaced my Board with no question asked....She referred me to the forum for further advise.
You Guys are real pros, and you have my complete loyalty.
Respectfully,
Al R. Wildomar, Cs
Originally Posted by: Firerepair  I Have a Kitchen Aid Convection/Micro It started beeping intermittently and some of the funtions where not working. I had a tech come out and he said it was my controll panel...I replaced the controll panel and all was good for about a month. It's doing the same thing as it did prior to the replacement of the new C-Panel, It there something else I should be checking for?
Respectfully,
Al R. Wildomar, Cs Al, If you're sure, you removed the plastic cover shield off the new panel, and you're sure you have all the connectios on tight,and the control board connector is clean, Your next move is to replace the control board, Part number: AP3131994
Good Luck, :) :) :)
