laundrysucks
#1 Posted : Saturday, February 9, 2008 1:25:36 PM(UTC)
laundrysucks
Im having problems removing the plastic covering over the dogs...
Tried everything short of smashing :mad:
Any suggestions on how to remove the covering inside the agitator would be greatly appreciated:)
mleflar
#2 Posted : Sunday, September 19, 2010 10:56:25 AM(UTC)
mleflar
I would be grateful for any ideas as to how to separate the top from the bottom. Some videos show that you just pull them apart. Mine is stuck. Are there any tricks or best practices? Thanks!!
Sublime54
#3 Posted : Friday, March 10, 2017 10:55:36 AM(UTC)
Sublime54
I know this is a years later reply but the easiest way to get dogs out is to use both of your feet on each side of agitator and lift up on the top part. Sometimes the fabric softener buildup makes it hard to pull top part off but it works.
