Somone
#1 Posted : Saturday, September 18, 2010 9:19:38 PM(UTC)
Somone
Change electric panel today after unstable feed ini the house for days. Everything working fine except cooktop and oven. Plug in stive works fine, Help
#2 Posted : Tuesday, September 21, 2010 3:48:25 AM(UTC)
Replacement parts for JENN-AIR JER8750ACW Range - S/c F/s Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16010161.pdf
From your post I am assuming that everything looks normal but none of the elements heat up (stove top and oven ).
It sounds like you do not have 240 volts going to the stove.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
