The washer will go into spin cycle but wont go into high speed spin cycle. resulting in clothes that are still soaked. All other functions work correctly. The washing machine is a top loader. Any help would be appreciated. Thanks.
DZL1.
Remove the front panel. Locate the LED on top of the motor, beneath the inverter cover and view it for diagnostic testing.
Report number of LED flashes during a 6 second period.
Thanks for the reply. I will check it out.
DZL1
The light is flashing in groups of 9. Hope that the info that you can tell me whats wrong with it. Thanks.
DZL1.
The 9 flashes means "the break resistor is open". The correction is to replace the motor. - The part number for the motor is AP4339494 Gene.
Thank you Gene for your time and help.
DZL1.
You're welcome. Keep us posted.
Gene, thanks again. You were right with your diagnostics! My wife is a happy camper!
DZL1.
I'm glad you were able to fix it.
