3 Pages<123>
booper
#11 Posted : 17 years ago
booper
How do I get the control panle potion of the dryer off to do the rest?
thank you so much. I am excited to try to do this on my own!
booper
#12 Posted : 17 years ago
booper
Oh my gosh, I made removing the lid much harder than it was. There were two screws on the back side of the control portion that weren't allowing meto lift it...I got it off and it was indeed the belt....now I need to figure out howto put the new belt in...I am so excited that I might actually be able to do this....any words of wisdom for belt replacement. Anything (other than grooved side down, that I ought to look for or be careful of. THank you again for helping me through this project...
#13 Posted : 17 years ago
Just to add my 2 cents to SublimeMasterJW complete instructions following you'll see the belt diagram (front view).
Gene attached the following image(s):
booper
#14 Posted : 17 years ago
booper
wow...thank you so much. the visual helps tremendously. I have ordered the belt and it should be here by weeks end. Hopefully saturday or sunday I'll have my dryer up and running again. I can't thank you all enough for your help and patience...not to mention saving me a lot of money.
SublimeMasterJW
#15 Posted : 17 years ago
SublimeMasterJW
SublimeMasterJW attached the following image(s):
booper
#16 Posted : 17 years ago
booper
cute...too bad you are on the other side of the country.....I'd buy you dinner
booper
#17 Posted : 17 years ago
booper
sorry...I am back.....I am having trouble with the idler. from what I am reading there should be a wheel on it but mine doesn't. there is like a 1/2 circle metal. I see how the belt goes around the pully how do I route it around this idler arm? (it is welded on both sides) do I kind of fold the belt and push the loop though and then take that loop around the pully? (this is the only moving part of this assebmly)...I hope someone understands what I am saying....thank you
ApplianceJunk
#18 Posted : 17 years ago
ApplianceJunk
Your idler is like the one on the left in this photo?
http://appliancejunk.com...n=gallery;sa=view;id=428
booper
#19 Posted : 17 years ago
booper
got it...it works....THANK ALL OF YOU!! It works!....if it runs smoothly doesn't make any noise...should it be ok??
I can't believve that I did it.... Wow!
booper
#20 Posted : 17 years ago
booper
yes the one on the left
3 Pages<123>
