Jacobh
#1 Posted : Wednesday, September 15, 2010 8:00:04 PM(UTC)
Jacobh
My whirlpool Duet washer starts washing fine, and then it drains but right after it drains it starts flashing FH and wont take in water for the rinse cycle. Why would it take in water for wash cycle but not the rinse?
dgdl441
#2 Posted : Thursday, September 16, 2010 3:38:59 AM(UTC)
dgdl441
Online shopping has been a trend now, so if you want to buy cheap boots isn`t a problem. The important question is what kind of boots style you like, in order to show it in front of your loved person? If so, the best quality and cheap boots is essential. our company Ugg boots not only beautiful but also very good quality,that is why in winter, best choices for women boots must be ugg boots. So where can buy best quality and cheap ugg boots. It is the focus of this article. First of all,the Internet so developed, it is also more stores of ugg boots will dazzling you, right? So hard to get one pairs nice boots to fited yourself. You have to sure your size, color, or even boot`s weight you have to consider too. When you think about the appearance of the boots, then you can start shopping. Here in ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com you can find all the newest ugg boots, and sizes are also able to choose, as long as you know your size. If you want to get big quantity of ugg boots or wholesale ugg boots,you also can choose from ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com. All the ugg boots are designed by the designer, using a high-grade suede material. Also ugg boots been made exquisite, so it can been a birthday gift or Christmas gift too !If you login web site after do not know how to deal,Can also be contacted,Their contact email is: service@ugg5803.com.If you have any better suggestions for products or website,You can also passed this email to contact. Original article: Transfer from ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com reproduced please specify
sidfink43
#3 Posted : Friday, September 17, 2010 5:06:30 PM(UTC)
sidfink43
If the machine does not fill up with water, the Central Control Unit shuts it down and flashes the F/H code.
Take off the top and inside you should find tech notes that will enable you to troubleshoot the problem. The likely culprits are the CCU itself or the Door Lock Assembly.
popspatrick
#4 Posted : Friday, September 17, 2010 6:36:12 PM(UTC)
popspatrick
check the cold water inlet to washer make sure they are not switched around hot/cold
popspatrick
#5 Posted : Friday, September 17, 2010 6:37:22 PM(UTC)
popspatrick
No water detected entering machine or Pressure switch trip not detected
Read more: Appliance Fault Codes
Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
