recently bought used sub-zero 550, so using temporary aluminum pan to catch water under 550 which I was told normally drips 4 times per day. However, it seems to be dripping too much, as I need to empty pan every day or I have water on the floor.
Is this normal or is there a problem causing too much water drippings?
