GE washer timer not advancing
[quote=Gene;275975]Gary,
It is very hard to diagnose such problem without the wiring diagram. If you do have it and can post it, it might help us to help you.
Gene.[/quote]
Thanks for your reply Gene. If I’ve done it correctly, you should see two attachments that will show the wiring diagram and timer settings. I hope this will help you come up with a solution.
Gary
GE Washer Page 1.pdf (65.5 KB)
GE Washer Page 2.pdf (110.1 KB)
