lbunay
#1 Posted : Wednesday, September 15, 2010 9:29:39 AM(UTC)
lbunay
I have a Kenmore 80 Series H/D Type 111 and the water empties out but the tub doesn't spin to wring out the clothes. When I went to remove the clothes from the washer they were dripping wet with water. I tried turning the dial to a different spin cycle and it was the same thing.
Does anyone know what the problem could be? Everything else seems to be working ok with the washer other than this problem.
magician59
#2 Posted : Wednesday, September 15, 2010 10:45:14 AM(UTC)
magician59
It could very well be a broken motor coupler. Does the motor make a gravelly or raspy noise in "Drain"? Look under the unit. Can you see shavings of black rubber or white plastic? If so, replace the coupler.
Part number: AP3963893
lbunay
#3 Posted : Wednesday, September 15, 2010 11:56:29 AM(UTC)
lbunay
Thank you I will check this out and post the results
lbunay
#4 Posted : Thursday, September 16, 2010 6:31:31 AM(UTC)
lbunay
I'm ordering the part you recommended #AP3963893 (Motor Coupler). I don't have a manual since I bought it used. Would you have a diagram of the motor so I know how or where these pieces exactly go. It would really help me.
